E
Edd
fucking piece of sht forum :x
never measured the inlet per say but,the exhaust and elbow is 4" stainless pipe.poss just doesn't look so big in the photo's :?Edd said:i looked at ones with ur engine on the stand with the turbo fitted and just the turbo elbow on..
is ur turbo 4 inch inlet?
:?: :?Edd said:f***ing piece of sht forum :x
then the inlet must be bigger than 4" as i'm almost positive the exhaust and elbow were made from 4" stainless pipe.i don't even have the car to measure it but i will measure it asap.just for you eddEdd said:i presume you have 4 inch inlet, so if you compare inlet to the elbow the elbow is most likely 3 inch
i didn't get close enough to that miserable cow for that :twisted: :lol: :lol:Edd said:although don't get that dogdy ruler out ur missus uses to make you feel better by thinking your bigger than you really are:lol:
What has having not enough money got to do with starting with an NA tuning base??? Some ppl have money, some dont like to do things the easy way. Why to do head work do u have to go back to the start of the tuning process?? Some NA tuning methods are the same and I was pointing it out in this context AS IT MAKES IT EASIER FOR THOSE WHO ARENT AS TECHINICALLY MINDED! just like manifold which was what this post started out as asking. When we are taught about engines we dont bother about turbos and superchargers as all they change in the amount of air that can be forced in, they dont change the flow of it. Taking the turbo out of the equation makes things easier to understand.oap-r said:who cares about what happens with n/a cars :?: unless i'm mistaken,none of us are taking our engines back to the start of the tuning process.we all have turbo'd engines and i can't see the point of "muddying the waters" with n/a tuning methods :? oh come on nad,be reasonable ffs.i hardly think that any of us,no matter how anal retentive we arenad said:Because I was just showing what difference they can have and it is clearly shown and easier to understand with NA cars. As with most turbo cars u should treat them as NA first, get as much power out of them like that then strap the turbo on. This was exactly the same route of thinking that Norris took with his Evo. No bit of info can be seen as irrelevant as its another bit of info for the mind.,are in the same league or have the same tuning budget as simon.
you,as well as several others on here,seem hell bent on reinventing the wheel just because you've read a few books,studying for a degree or because somebody labels you as a guru.
wtf has restrictors got to do with us :?: we all seem to be trying to increase power/torque levels not limit them :? the rally teams also have various ways and means of increasing the power/torque levels that we don't have access to.quoting n/a techniques to a forum of turbo nutters just confuses the issues we are dealing with.nad said:Once again I was making a point about what manifold designs can do to the engine. U may have the same figures but strap a 34mm restirictor on ur turbo like rally cars do and u will lose it all. The point was about matching ur manifold to what u want. Even so it is not as important on a turbo car every little helps so once again this is why I put the NA stuff in here. A turbo'd engines manifold will still roughly work along the same principles.
if someone on here asks questions about getting the most out of their cars engines,it's up to us as a group to give info that we know works,is reasonably practical and doesn't cost the earth.we shouldn't be quoting from text books and filling their heads with impractical,uneconomical bollox.
I thought we were just on about flow of air through the engine323GT-R said:I agree to some extent with the follow N/A tuning principles on a turbo car, but not fully. The requirements of a turbo engine are different, and the steps to be followed and the methods used have to differ to get the best results.
If you took the cams from a 300BHP 2 litre non turbo engine and stuck them in a 2 litre turbo engine with the same timing, it would run like cr*p for example. Also with a non turbo engine, you may look to increase capacity by maximising the bore and stroke, on a turbo engine, this wouldn't be necesary, as the turbo can provide all the air you need, hence the strength of the bore becomes more important than the diameter. As has already been mentioned, things like pulse tuning are almost impossible on a turbo engine. Just a few examples of the differences![]()
Doesnt it suck it out though323GT-R said:lol! Are we far enough off topic yet? :lol:
Airflow through the engine is different, that small wheel in the exhaust really screws up the airflow...![]()
