speedo/turbotimer
H
hijacker1
my turbo timer stoped working,it has power coming to it because the lights come on but it doesnt actually work,when this stopped working the speedo also stopped working.the rev counter works fine and to my knoledge the car is still limited to 112.any ideas on what it could be and how could i check it?
Not sure to be honest, but you've just made me wonder if the second turbo timer I found in my car has anything to do with my speedo playing up. :?
You could maybe try disconnecting it and putting the wiring back to factory spec.
jonee
turbo timer
hi,wen my t/timer failed it turned out to be the rpm feed from the ecu
to the t/timer unit.this can mess with the rpm gauge in the car
H
hijacker1
Re: turbo timer
thanx will tell the person this wen i get it checked out.
