Blows white/grey smoke when the engine is cold. Idle seems smooth. Smells like burnt oil at times inside the car. But this may be dripped when checking the oil.djdoc360 said:Im guessing your not blowing grey smoke out the tail pipe. So maybe you do have a leak somewere. How is your idle?
saddler said:Whats amount of gear oil would i need to buy to fill the gearbox up..
thanks in advance..
yeah sorry...Odin said:Not that it hasn't been asked and answered god knows how many times :doh: :roll: , But it's 4.5lt in the gears box and a little over a litre in the transfer box.
saddler said:yeah sorry...
thanks in advance ;-):-D
yeah sorry...Odin said::shock: :shock: That is possibly the most stupid question ever on the forum :shock: .
What part of 4.5lt didn't you understand then :der: :lol: :lol: :lol: :lol: .
They only come in 1lt bottles so it would be 5lt's I'd assume that you would need to buy, Giving you 1/2lt spare :roll: .
I think im having a ground hog day sorry :-DMINESGTIR said:oh hes trying you today odin
We towed it about 5 miles, without the engine running justingntion on. Is that not a good idea???? I'm worried now!abyss said:i would take the abs fuse out and check the earth on the battery, also check the earths behind the 2 headlights.
When you say you towed the car did you use a flat bed?
Mine smells asif it is throwing neat fuel out of the exhaust, i have got an ECU coming just in case. I am/was sure all the earths are ok but now i am realy doubtfull. I'll see on Wednesday.pulsarboby said:if the engine oil smells of petrol then the car is overfuelling big time, which you need to sort out desperately (or you will end up with a wrecked engine, as did i:roll: )
as everyone else has pointed out, earths, earths, earths! check them all, especially the 2 on top of the inlet plenum;-)
if you find any loose or unconnected, then you may have created a spike in the ecu which has blown the injection circuitry apart, 'had this before on an astra' in which case you will need another ecu, but make sure those earth connections are all connected, clean and tight.
you will then obviously need to change your engine oil again, as that whats in there will be p1ssed down with fuel.
as i said, ive seen these symptoms before with an astra, which got that bad it was throwing neat fuel out of the rear exhaust, but it was a bad earth which had caused the ecu to spike and go bang!
if you do need another one then i do have one in stock.
