PowerFC / Datalogit and Wideband LM-1 dont work ???
radiobar
hi !
i tried to connect the LM-1 wideband to my datalogit.
LM-1 output is ok and works 0-5 V (checked with voltmeter)
i tried 0V and AN1 and also delta AN1-AN2
but when when watching the map i get only zeros.
any idea ?
got the black datalogit (V2.0)
thanks
bye.
stumo
You need to go into ; [setup],[auxillary] and change the values in AN1-AN2 to whats in the picture and connect the pos and neg outputs to the AN1 and AN2 connectors.
Danny, the O2 feedback has nothing to do with logging the external data.
The O2 feedback does just what it says, the ecu uses (or not if it's switched off) the feedback from the lambda sensor to run the engine , when in closed loop, to whatever you have set it to.
As standard it's set to 14.7 but you can change it to whatever you like.
