Power steering fluid
jpward
Ok i seam to have sprung a leak and well theres fluid all over the oil filter and housing all the way round to the lower pulley and its deffinatly PS fluid nice and red so has anyone's R done this and what is the usual cure O ring/copper washer replacement on pipe ends as no hose looks to be burst?
When my pump went, it was leaking out of the end of the shaft that the pulley mounts on. It might be worth taking the belt off and see if there's play in the shaft/pulley
jpward
Ok ill give that a go doesnt sound like im gona want the run out to be too bad :sad:
