Lambda?
Shaun
:D Hi guy's,posted this in the sticky above,but no reply :roll: So trying it here incase no-one saw it :lol: Right,i did a lambda check on my car a couple of weeks ago and when i started the car in the checkmode and flicked the throttle the engine check light flickered as the revs rose and stopped as the revs dropped to tick over,is this correct :?: Also did a check on my mates car as he has been experiencing intermitant power loss and when i started his car in the check mode after about 10 seconds the engine check light came on and stayed on for around 20-25 seconds :? .So is his lambda knackered or mine :?:
I must not have posted my reply then, cos I did write one :?
Did you do it as per the manual? if you did it tells you in the manual what it means when it comes on/off flashes etc.
Shaun
:D Hi Fast Guy,nah mate,i read about the check on here :wink: and did it that way.I'll see if i can find my disc out and check the manual :wink: Thanks mate :D
