someone wanna edit the write up, and change the oil pressure thread, where it says its definitely 1/8 NPT to 1/8 BSPT (Tapered)?
might save some confusions!
this
Make sure the new oil pressure sensor has a 1/8th NPT thread as that is what the original GTiR item is! This way, a direct replacement is easy. Plus, find a boost hose in your engine bay which you can insert a T-piece into to read the engine's vacuum AND boost pressure. For example, if you have an aftermarket dump valve, the hose leading to this is perfectly acceptable.
to
Make sure the new oil pressure sensor has a 1/8th BSPT (Tapered) thread as that is what the original GTiR item is! This way, a direct replacement is easy (OR purchase a 1/8 BSPT female to 1/8 NPT female adaptor, or failing that purchase a remote braided line kit, like the Subura remote oil pressure switch kits widely available).
