help fans not working
murdocgtir
ive checked the fuses all seem fine, also ran a link from battary to fan direct and it works!! the temp gauage reads norm even after a good spin. i letf the r running and the top hose gets hot and the bottom one remains cold, so this is where the help comes in!!!!!!!!!!! any ideas :oops: :roll:
GAZ P
Most cars have a fan switch, gives a feed to the fan motor when the coolant reaches a set temperature.Normally fitted into the rad but not sure on the R :?: :oops: :?:
ard1ey
Rad fans are switched on by the ECU, have you checked any fuses / relays that are in the circuit? I think the rad fan relay is in the box on the drivers side inner wing.
murdocgtir
re
have it sorted brought her for a good spin :lol: and left the car running and about 10 to 12 mins later both fans kicked in, before that id bleed the system maybe there was an air lock but workin now phew!! :D
