just need to get my flywheel off, what tool is needed to undo the bolts. its like a multipointed star, is it a specal tool, and where do i get one. answer needed asap pls. cheers :-D
ok, i thought it may be a multipoint socket, they r def bigger than 13mm/ half inch. more likely 17mm. i know last time i undid flywheel bolts they were real tight lol. just needed to know it aint a special tool. its to get the os giken flywheel off.
cheers guys
there 17mm 12 bit socket as keiron pointed out.
if you havent got an impact gun then use a ringspanner on them and give it a heavy clout with a club hammer, that will break them loose
