Do i need a fuel pump?
samellio
As above really.. I'm only running 1 bar with standard turbo and plan to maybe raise boost to 1.2bar...
For those of you that have an uprated pump have you ever found that when on track or cornering hard the car cuts out???
Thanks..
Sam
J-GTi-R
People with the Bosch pump find that, as the fuel pick-up doesn't go far enough into the tank. The Walbro can just use the standard fuel pick-up, so no problems.
1.2 bar, I would recommend an uprated fuel pump for peace of mind if nothing else as you don't want an overworked and tired standard pump leaving you needing a rebuild.
samellio
Which walbro fuel pump is it?? There seems to be different ones...
