Couple of quick ones please
keastygtir
Hi Guys
Just a couple of quick questions if you will indulge me.
1: Fuel feed and return on the rail, which way around?
2: Torque settings for the crank bolt
3:Torque settings for the rocker stoppers
4: Pipe ID for the PCV breather system
Thanks as always!
grim_d
1. The complete opposite of what you might assume. The return line goes onto the end where the pressure regulator is. You will soon know if you've done it wrong as it won't get fuel and you will spend a day turning it over and scratching your head.
2. 3 white knuckles or a handfull of dakkydaks.
Google suggests 105-112 lbft but consult the workshop manual if you want to make sure.
3. Same as cam caps since they pick up on those bolts. 6.7- 8.7lbft. You will need quite a dainty torque wrench.
Theres a sequence to them so again consult the workshop manual.
http://www.gtirworkshopmanual.com/default.aspx?v=210
4. Measure one of the ends? But about 1/2 inch I think.
