jambo_gtir
Right guys, I have spent ages searching the internet and forums about this and still not sure what to do.....
The problem I have is my engine is using oil and blue smokes a tad after over-run down a long hill (then re-applying throttle) and also when I come on full boost it smokes initially then stops.
The engine build is less than a year old with about 5000km on it. I have done a compression test and leak down test and both are good. I have also recently replaced the valve stem oil seals with some supertech ones. Also, I bought a brand new turbo off Bobby a few months ago. It still burns oil......
I think i know what the problem is: the new bigger turbo (3071r) meant that I had to change the oil return to the block. I spent weeks buying different bits of samco hoses and 90 bends etc to try and get the oil return to travel down to block. Due to the position of turbo and adaptor in the block its is so hard to get a decent oil return. I know that this is simply gravity fed so needs to run 'downhill'. Anyway, I finally have an oil return that is almost downhill when the car is level....
The next issue is my breather system which i suspected was crap and hence pressurising my crank case (addidng to the oil drain problem). So i took standard system out and put my own in. The engine does seem to run better now and I think the oil problem has improved but it is still smoking on initial boost and burning oil.
Just to mention I am running quite big ring gaps so i suspect have more blow by than standard.
Basically.... i know most people run the breather to atmosphere but I am thinking about running mine through my catch can first and then back into turbo intake (as Nissan does). I think this would 'suck' gasses out causing more of a vacuume in crank case and impoving my oil drain from turbo (and hence stop the oil leaking from turbo seals). The trouble is on most forums people say there is no vaccume in the turbo intake pipe? how is that possible when the turbo is is sucking in air hard??
Is it really that bad to run it back through turbo like Nissan does? most people argue Nissan only do it for emissions but i think it's more than that....it must suck the crank case gasses out to create a vacuume and promote ring seal surley?
Sorry for long post, this is just the final thing wrong with my Pulsar now and I really want to sort it out before I end up driving the thing off a cliff!!
