ABS Removal
nathan
right i have got my pump out this morning wondering can i now get rid of the ABS ecu (and cut the plug of and remove wiring) or do i have to leave it in ?? Also the 2 pipes coming from the master cylinder can i plumb them into the splitter ??
cheers nathan
youll need a non abs brake proportioning / splitter valve which i have if needed!
you can then completely ditch the abs assembly with ecu
1,000000000000000000000000000000000000000000000000000000000000000000000000000000
no actually il do it for 1,00000000000000 with discount!
or bring me £50 and that will cover your wind deflectors, bolts and the proportioning valve, actually the non abs ones are quite rare so i reckon you owe me and the mrs a coffee too:-D
