A few questions
PlayaDaz
Hi there folks. Just bought a pulsar etc, doing all the jobs in turn that need doing, first off been told i need rear discs and o/s r caliper. Are oe grade pagid discs and caliper acceptable as i drive sensibly, and its under 300 hp:-D. ? And im guessing the rears take less bias. Have an annoying squeak from the rear that goes after a bit also. ? common ? Lastly, who is my most local gtir specialist and rolling road you lot use. Thanx in advance from a noob
Yes. - As you say the back axle does less braking than the front axle, and there are plenty of people with upgraded brakes at the front running standard brakes at the rear.
Sounds like you've got a sticky calliper. - Probably the one that needs replacing?
Mine hasn't been on the rolling road for quite a while, so I can't really comment on that.
