steve963 said:Ive got an RB25 AFM to fit (like the Z32 but only good for 320ish IIRC). I also got emanage blue.
I guess if I swap this AFM for the std one, the ECU will be reading less air than it expects, and fuel less, so I need to increase fueling?
Also less air signal (meaning a slower burn) will make the std ecu advance timing more? ie from 20 before to 25 before TDC so i would also need to retard timing?
not really, it maxes out at about 5krpm IIRC so makes mapping difficultstumo said:you can do 320 on the std AFM
I can adjust the fueling myself with my wideband and Emanage blue, but wont I need to adjust the timing?steve_fctuning said:yes, but ensure as above you get it remapped to suit or the car will run rich as hell and bore wash will occur.
Boooooost
the RB25 and Z32 maf resolutions are different.
however, you are correct in that the RB25DET is a good and cost effective upgrade for the RB26DET (its a cheaper alternative to the 400 quid Nismo AFM's whos resolutions is nigh on identicle to the Z32) why folk waste money on the Nismo's i have noooo idea. you may as well get twin Z32's if you own a Liner....
You can run RB25DET maf though on your SR20 no probs. ive mapped a few with this set up but the Z32 is really the one to go for if shooting above the 350whp mark
