Z32 maf fitting quicky
boucherie
Just a quicky, when fitting the z32 on a power fc is it simply a case of plug the z32 in and select it on the controller?
if not then what else needs to be done, do i have to reduce the %figures by a specific amount?
also does the same apply when going for the blow through setup as opposed to the draw through setup again on a z32?
AJ4
just fit it and select the z32 on the controller.
you will probably have to rescale the load axis depending on what boost you are running as most people run off the end...
