Yet more problems.......please help!
Jonny_gti-r
Ok so the cars been in the garage (AGAIN) and now when hooked up to the Nissan computers it is coming up with a camshaft positioning sensor fault. The mechanic said it was basically a new dizzy job and that it will be expensive........!!!!! Anyone know about this?????
Really would appreciate your comments
Jon
jiw
check it is plugged in properly, four pin plug under the dizzy, i plugged mine in the wrong way which is possible, it then showed a fault code 1-1.
also why are you paying somebody to do a fault code check when it shows you how to on here, save yourself some money :D
Jonny_gti-r
Car was in having the det sensor wiring checked out after i had found a fault doing the code check myself. Nissan were supposed to have fixed that problem then found this one with the camshaft position sensor!!!
H
heaven is a gtir (bry)
I dont know about the cam positioning sensor but i just bought a new dizzy cap and rotor arm for £17 yesterday. :D
Local motor factors. :wink:
Posibly try these before you try a new dizzy.
Bry :D
