GTI-R Kid
With funds tight due to other commitments at the moment, a friend has suggested replacing the single knackered piston in our engine with another one. He reckons that just replacing the one piston, along with the bearings, will see the car up and running fine again (or at least until funds can be raised for a full rebuild). He seemed very confident that it would be ok, and since he has some expierence rebuilding MR2, 200SX, 3000GT and other engines i'm half confident in what he's telling me.
What i was wondering was if this is a viable option? As far as i'm aware theres no head damage, and the cylinders haven't been scored either. For all those who've had or done rebuilds on their engines, have you ever tried this and what was the result?
For a little insight into the senario, the piston holed itself due to fuel starvation (i think). There was a bleed valve fitted at the time, but it was in the closed position meaning the car was running close on standard boost (any hike over normal would hav been down to the K&N and the Mongoose). Going round a bend the fuel surged leaving cylinder 1 empty and the piston went. It destroyed the tip of the spark plug in the process.
Also, while on the subject, does anyone think that the bleed valve being fitted could have contributed to the problem? It had been set to 0.9 bar (checked on aftermarket GReddy boost gauge) and was run at that pressure without problem for early 9 months. Personally i don't think it would have contributed, but others i've spoken to aren't so sure.
Before anyone slates me for looking for a cheap fix, and lectures me on how i shouldn't be running a car like this if i can't afford it, please save your flames. With moving home and extra expenses to think of right now, i just can't afford to splash out on a full rebuild. I want the car back on the road, so i want to know if its madness to replace a single piston with another standard one for the car to run until there's money available for the forged pistons and everything else involved.
Any help much appreciated folks, as i'm kinda missing the car now its been off the road for .... well i wont say how long since its kinda depressing.
Thanks.
Thanks.
