forge400 said:hi
Just a quick question I am running 387bhp at current with my standard injectors maxed. I wanted to know with my Super Hybrid Turbo and adding z32m.a.f and a tubalor manifold will i push 400bhp at 1.5bar.
Thanks
forge400
SickBoy said:I had 346 bhp at 1.2 bar and Daz had 355 at 1.3 bar ....both standard injectors
Lee
Thunder God said:And who's magic rollers where those two reading's taken on :? :? .
We all know that most tuner's will "make sure" you get the best out of your cars on the rollers, I was chatting to the bloke at wallace tonight and he said he could of given me another 10-20bhp if I wanted on the print out :shock: , I asked him if it was real power and he said no :doh: , So why would I want it then :der: I'd only be cheating myself I said :roll: .
So how come Jason Gant uses a SAFC 1?and has no issues?Simmo said:id go for 700cc's to achieve 400bhp at a decent duty; plus that then gives you the ability to go for more power without the need to buy new ones. Haven't read your car spec but you'll need an ecu upgrade (emanage/powerfc etc) to be able to run them.
I wouldn't bother using an air flow converter (such as a SAFC-II) as they dont provide enough flexibility to use the 700cc's properly (mine didnt anyhow). I think the SAFC-II can only handle +50% in a size change to standard injectors - which the 700cc's are not
i thick he only uses his car for drags only so that probly helps as well8)Shaun said:So how come Jason Gant uses a SAFC 1?and has no issues?
