JIMMYBACK said:
andy chan where are u
How did I get dragged into this :?: :roll:
Anyway, here’s what I got for mine. All prices are approx.
Custom cams (272 duration with 11.5mm lift) and vernier pulleys @ £600
4 shims @ £72
Custom turbo spec’d for 450bhp @ £900
Forged pulley kit @ £200
Head studs and caps @ £200
1.2mm head gasket @ £100
87mm Forged JE pistons @ £400
ARP Rod bolts @ £50
Lighten and balanced bottom end and knife edged crank @ £400
Balanced con rods with pistons and ARP rod bolts
Balanced flywheel
New water pump @ £42
New oil pump gears @ £80
New hoses on back of block (6 in total) @ £55
New chain @ £80
New chain tensioner @ £40
New chain guides @ ?
All new bearings, mains, small and big ends = £100
Engine gasket set @ £150
All new nuts and bolts around the engine both internal and external @ ?
Helix racing organic clutch @ £400
New various s/s hoses and pipes @ ?
Solid engine mounts @ £150
New various uprated bushes, power steering, anti roll bar, gear shifter, anti lift kit etc, @ ?
Gear box rebuild @ £200
Sard Fuel Pressure regulator @ £145
Then there’s the labour on top for the rebuild!! :shock:
Things still on my shopping list are:
Power FC Pro
600cc Injectors
Z32 MAF
Setting up to 1.6 bar to run 400+ bhp @ ???
As Kieron has said 400bhp can be done on stock pistons but the fueling has to be 100% spot on. The yanks have been doing this for ages now.
