Works handimg kit fitted but got a problem
minimivic
Spent all day fitting the Whiteline handing kit. 9Hrs from jacking up to dropping in back down again :shock:
No problems fitting all the damper inserts and the rear suspension want together really easily :D
Probels are at the front, The sway bar mounting point on the chassis has started to come loose. Its a box type section that the sway bar bolts to and extends down the length of the car. Has anyone come accross this problem before and is it just a case of welding it all back into position?
What damper setting are you running, Was told about 180 degrees back from full hard is that about right?
skiddusmarkus
I had that happen recently.My dad welded on some p[late and it's fine now.It's a bit fiddly getting it right so that the bolt still goes through the hole but then again it wasn't me on my back doing it :lol: .
