Working rear caliper
Tim GTiR
I suspect the piston isn't retracting properly, and as a result the pad is slightly riding the disc as I drive.
Theres a squeeking/squelling noise coming from it as I drive at low speeds, and I've had the pads off and there is uneven wear to the pad, so I'm going to try another caliper to see if the noise stops
stu-gtir
mine did the same thing, all i did was give the caliper a good wack with a rubber mallet and problem solved.
Stu.
