little ghost
Right, noticed the other night that the R was a bit slow in firing up, also the cranking was slow. So i thinks to meself bugger my battery's on the way out. Then the problem got worse like you would expect if your alternator wasn't charging the battery properly or if the battery wasn't holding charge. :?
This morning it wouldn't crank at all. I've tested it and it's fully charged so doesn't look like it's that or the alternator...
Fault code is giving 34 det sensor, although my instincts tell me this is a false reading down to low voltage when i try to start the car...?
Starter motor is a poss? Help please...
