Window keeps going up
Stoned
Bit strange but I can here clicking in my drivers door and my window goes up on it's own accord
Whats that all about
window up switch/mechanism might be jammed in.might just need the switch "flicking" a couple of times if you're lucky :D
if not,you might have to take the switch apart :(
B
Brett G
Yeah most likely one of the window switches, unplug them and see if it still happens? If so then it is the wiring (maybe chaffed or something) but unlikely. If there's nothing obvious with the switch then you could try some switch cleaner and work it/them a few times.
Brett
Az
If that doesn't solve it (seems most likely looking at previous posts on this) do you have an immobilisor system fitted that when you lock the car with the windows down they automatically go up and shut?
Might be the power module for this (at least it was for me :roll: ).
