Its not normal as im sure they were not designed to do it but its very common mine does it! as do alot of others . Cures are new door rubbers its also been said if you bend the top of the doors in ( bit dodgey)that helps . Also new door hinges may help im going to order new rubbers from erics this week as a starting point.
It's proabably worth looking at your hinges too; I know mine are pretty droopy, and I don't see the point in chaging the seals whilst the hinge isn't doing a great job of holding the door in place.
Having said that, it's been much better since Geoff and I had a go at adjusting them. I would recommend trying to adjust the doors back to square first, then see if you still need to replace the rubbers.
yes I know that but the dealers are all franchised so they source their parts from different places. I thought you might know of somewhere less obvious and cheaper.
