Will this work for our cars?
GTiR_Mic
Why waste your money tring to get them to fit mate, just speak to Rishi and he can get you some top quality stuff.
Mic
Ricky_GTi-R
Mic
Yeah thats true a suppose, hows your shed coming along???:lol: :lol:
ashills
reason to buy these is because its about 600 quid all in then u just need to get machine work done
AJ4
there is only a couple of mm difference between the standard piston cut-out and the bottom skirt of the CP's. If you were _really_ careful and had some pretty accurate scales you could do them at home with a file ;)
Mr GTiR
Why mess about when GTiR 87mm forged pistons can brought for less than £400. That price is delivered from the States!
Simmo
I thought that most people tend to limit themselves to 87/88mm for diameter because of the strength of the block and thus people really wanting 2.2 litres go for increased stroke?
ashills
the reason for these is the the gtir has a briliant bore stroke ratio as standard and is still very good when using a 90mm piston so u stick a liner in that strengthens the block for starters then u can bore it to give a 2.2 capacity that will spool turbo faster etc make car more torquey, also still be able to rev the engine to 9k which is a rarerity with most stroker kits as you normally increase stroke and retain piston size ie on the evo to change the capacity to a 2.3 you end up with 100mm stroke and 86mm pistons which limits revs to a maximum 8-8.5k rpm
AJ4
yeah, but who wants mincing little 87mm pistons :wuss: :behindsofa:
