Wideband afr
Pulsar dan
I'm after a wideband afr any make or model just working condition, in a bit of a rush for it so would be handy if someone has one. Thanks
Isn't that odd. - I was just looking at them myself; I don't need one, so I'm not willing to just splash the cash. However, I was thinking about those "Tech Edge" units as a starting point, but am nervous about trying to build one myself.
There are a couple for sale on eBay that will need a gauge, but everything else is there (actually at least one of those will have ended by now).
Pulsar dan
I have wanted one for ages as I go through cars like anything and is nice to no what they are running like with constant view off fuel ratio. Have seen a few on eBay missed a innovate one what was cheap. How much do you charge for them ed? And what do you prefer?
Jon Olds
Got one in a bag that I bought 2 years ago and never used. secondhand, but I saw the car he had it on and he assured me it was 100%. £100 plus a fiver postage. pm me if interested
johnsy
it comes with a boss to weld into your dp, iv heard the innovative ones are a chew on,
i picked up a used AEM for 80gbp ~(local)
danr
run 2, some can provide a narrowband feed, but they can't mimic the titania sensors (what we have) afaik
I'm surprised to hear that; I would have thought it was easy enough for the wideband controller to output a simple digital signal for the ECU no matter what the source was.
geoff pine
I did try this but for some reason it moved my a/f base from 100 to 110 this in turn altered the o/2 signal (it never sat at zero) even when warmed up it was trying to stall from a stand still.
Well there you go, I've learnt something new... I am going to need to put a new boss in if I want to run a wideband at some point because they don't play together.
Fusion Ed
It would take a bit of messing about with the settings but you could emulate it with the LC1 if you wanted.
