WHO KNOWS HOW TO USE A PROFEC A ?????
Y
YODI
Anyone know, what are the three little knobs on the bottom right corner and what does each one do??
Thanks, Yodi
C
Crazy
Speak to a member on here called duey as he has just had one fitted 8)
Y
YODI
Im in London.
So does anyone actually know what they do??
Cheers, Yodi
MORRISMINOR GTI-R
basically:-
Offset- this adjusts the difference (if any) between what the controller gauge reads and what your boost gauge is reading.
Time- used to adjust how long the 'overtake' boost lasts (in seconds)
Ratio- this is used to adjust the difference between low and high boost(it is basically for setting your high boost level.
Y
YODI
Thanks for your help mate, but does the profec a has 2 different boost controlls??
Yodi
MORRISMINOR GTI-R
yes mate the low boost is standard which is adjustable of the knob.High boost mode is when u hold the OTB button in for more than 3 seconds, the red will stay lit :wink:
Shaun
:D Hi guy's,i've just fitted the one on Duey's car :!: The balance button is for correcting hunching(boosting,then dropping off)or for correcting overboost :!: The next one is VOLUME1,this is for the lower boost setting,in Duey's case i've set this to 0.8bar.And the next button VOLUME2 is for the higher boost setting,again in Duey's case i've set this to 1bar :!:Also with the unit switched off the boost is at standard 0.7bar :!:
Y
YODI
Cheers Shaun,
can you give me a little more detail pls like what they do depending on which way
Thanks, Yodi
Olly
YODI- you got a MK1 escort or is there someone else with your name?
I have a Profec A, bought with no instructions have had if for 3 years just leave it on 1.3 no need for OTB! :lol: all the instructions are on greddy.com go there and download them they have the whole manual 8)
Y
YODI
Yes mate i got a cossie mk1 escort which ive taken a deposit on.
Theres only 1 Yodi :D
MORRISMINOR GTI-R
Think you might be refering to the profec b there mate. the profec a has 4 buttons in total.
1 main one to set low boost, then a ratio, time and offset button :wink:
The american greddy site have the full instructions of the profec a in their electronics section. It shows you all the correct settings for the DIP switches on the back of the unit as well.
profecA
The American Greddy Site have the full instructions on their web site in the electronics section. It also tells you of the correct position of the DIP switch positions on the back of the unit.
