F
Funkmaster_stan
Hi there...Anyone here has the above installed on their iR...Wanted to know the best configuration and expected results from the different angles :idea:
For those who don't know what the product is: This kit is designed to lock and or change the inclination of the rear sub-frame while removing bush compliance in Nissan Pulsar. The kit contains 4 small (2 with cut line) and 2 large engineering grade low compliance polyurethane rings.
The rings are used to preload the sub frame mounts removing the excessive compliance.
