Whiteline 4 point underbrace
johnsy
im sure theres a brand new one on the other site for £85,
iv not long had the cusco one that i picked up for £55 needs stripping back and little welding, but for the money id say there more noticable than a strut brace
The only issue with them seems to be clearance with larger-bore exhausts.
Having had a couple of bent wishbones, I like the idea of them; they hold everything nice and straight under the car (and would have prevented me doing damage when one of my wishbone bolts was stripped and pulled-out letting the wheel grind into the arch). I just can't convince the wife that I should spend money on one.
If you want a stiffer chassis then it does help a little, but just to buy it on its own isn't really going to make masses of difference.
You are best having front and rear strut braces accompanying the under brace; also if your car is quite low, you have to take into consideration speed humps.
I run a 3” system and the Whiteline unit missed it by about 5mm, however I think the Cusco unit is not as accommodating.
waste of money for a road car if lowered!
soon as they hit something they snap at the lugs and therefore do precisely zilch except rattle about lol
if a track car then good bit of kit
Paul
Cheers everyone, i guess ill be leavin it then as i'm only going to be using the car on the road..
Trondelond
I've got a whiteline underbrace lying about, and I'm wondering if I should slap it on. My car is a daily driver, but it's just lowered about 25/27mm.
Would I run into problems? Of course I'd have to stay away from the most aggressive speed bumps, but..
And does fitting it require wheel alignment afterwards?
darkyGTI-R
Just buy one anyway lol bloody women:doh:
