wheel studs
GTIR1000
i have some extended wheel studs to fit do the orginial ones just knock out i gave one a few hits with the hammer didnt really move
jamie
Yes, but only through that little access port in the back of the hub; you'll need to rotate them until they are in front of it, then belt them with a hammer (then rotate to do the next one).
You may also find that you have to use quite a bit of force to pull the new ones through, but once they're in, they're staying there.
johnny gtir
there tight there on little splines. use a socket as a spacer and a spare wheel nut or two to pull the new ones in if your fitting spacers do not use them to pull on or they will end up mashed
GTIR1000
do i have to take the hub apart now then cause the shield behind is too close to the holes and i cant get the new studs in :(
