madcabbie
Hi guys, Whats the easiest way through the firewall to access/feed the boost gauge vacumm hose. I have a photo which shows access via gromet hole at the top right of the firewall. but mine has heeps of wiring and a pump if somesort infront of this hole, but i can move them to access this.
The problem is reaching the vacuumhose from the inside of the car. I can't see this hole when looking from under the passenger side of the dash. Do i need to remove part of the dash? The glovebox is easiest enough to remove. But then I see a think pipe and relays and other stuff in the road.
So is there an easier way to get the vacuum hose through the firewall to the dash? Should i drill a new hole?
Any advice would be appreciated.
Thanks
David
Thanks
David
