what the hell, you wont beleive this.
skprod
i don't know what made this.. i'v put new je forged piston 2 week ago, did about 2000mile since, running at 17psi , suddenly when i pulled in second gear, camshaft cracked and rocker cracked to the same piston. sound like the piston tapped on the valve, but piston/bearing/crank is okay, so what did that damn ?!
you threw a rocker which has jammed under the cam, seen this on a couple of occasions.....renew your timing chain as well as tensioner as both will now be buggered.
