what size vacuum hosing?
beau
hi, does anyone know what size vacuum hosing i need/what people use?
i want to replace the hoses from the inlet to dump valve, boost guage etc but no idea what size they are, im going to leave the hose which his slightly larger than the others, just want to replace the smaller hoses, on ebay they sell 3,4,5,6,7mm etc?
It depends which line you're looking at; I think it's 6mm and 8mm, but I can't be sure without measuring (and I'm not doing that right now).
skiddusmarkus
Does the bore actually matter though when the sizes are so close?I could see how if you went from 4mm to 14mm it might make a difference to how quickly the BOV reacts but when the sizes are so small does it affect it much?
Isn't it more about which nipple it will fit on? - In theory it makes no difference as vacuum and pressure are static values and not affected by the change in flow through different hoses.
beau
i know i can measure it, not hard, but i wanted to know what people use, you can probably used 2-3 different sizes, if i buy the size it measures it may be too big/loose but the smaller size might be too small, hence asking, im sure someone on here has replaced the vacuum hoses
stumo
just buy several sizes, they will come in handy
