This is the carbon canistor which is no longer usefull. Rip it out. Two of the upper pipes connect to the plenum. Block these off. the lower pipe comes from the fuel tank . feed that to the hard plastic pipe sticking out of the bulk head in the same area. Job done.
no not coxies had the car a couple of years now still no where near finished though im trying to put the engine back together and to be honest all around that carbon canister theres a few pipes and i havent got a club where they all go.
the two underneath you join together so it looks like the pipe from the firewall is joined to the pipe in the chassis. you will need to chop the hard plastic pipe till you can put the rubber pipe on. one of the top pipes goes right underneath the plenum all the way to the other side of the engine. block this off and finally one pipe goes to the nipple close to the fuel regulator. block this one aswell.
