What does it mean when GTi-R...
What does it mean when everytime you go start your GTi-R, you have to clean the plugs because because their full of oil?
8)
Sorry about it being in the wrong section :oops:
Yep everytime?! Re-build time then is it? Whats failed? :cry:
Do you have the right plugs in? They might be cold fouling. If they're the right ones, then your engine needs a rebuild at a guess. :(
jasegould
Is it definately oil and not petrol?? Coz if its oil then yes its rebuild time.
Yep their the right plugs, and its deffo oil! Whats failed :?:
Jonno
Where is the oil, on the plug electrode or up on porcelain section where the plug lead goes as if it is the porcelain section it is probably just the rocker cover leaking down the plug hole which is good news :!:
jasegould
Do you have to clean them before you start the engine or after its been running a while?? Are they new plugs? Are the plugwells dry??
Where exactly is this oil? In the plug well on the outside of the plug, or in the cylinder coating the plug?
If it's plug well, the it'll be the seal on the cam cover, if it's in the cylinder it'll be rebuild time.
skiddusmarkus
Easiest way to find out is get it compression tested.Ant garage should have one but if they're gonna charge you for it then buy your own-about £20 from Halfords.Compression should be around 10-11bar(147-162ish psi) in each cylinder with no more than 1 bar(14.7 psi)or so difference between them.
