You still haven't given the info needed :doh: :lol:jocster76 said:rishi my bottom end will have hks 86m pistons knife edge krank, jun rods arp bolts and every standard part replaced e.g iol pump and so on. im thinking of running a gt 30/76
cheers
JOC
any advice would be great
http://www.gtiroc.com/forums/showthread.php?t=30439jocster76 said:cheers for the advice oap
my spec
hks86mm pistons
knire edg crank
jun rods
sard 800cc twin hole injectors
sard swirl pot
fuel pump
fuel reg
my spec zuast
front mount ic
maybe gt30/76
apexi power fc
cryo font mount kit
and maybe alot i forgot
but this cam choice is doin me head in, maybe some jun cams and double valve springs or what, i dont know?
After a 30 sec google search,here's a couple i managed to find :doh:steven_c said:where are you looking at buying your cam's from? website? shop? which one?
It all depends on how you want your engine to develop it's power/torque.jocster76 said:cheers for the link OAP but ya confuzin me even more now
just been looking at the piper cams
piper ultimate cam may be the one for me or will jun be a better choice?
I havn't got it yet :doh: people keep blowing up my engine :doh:jocster76 said:OAP what torque figure do you get from 520bhp with fast road cams and where did you get them fom if ya dont mind tellin me?
2.2ltr stroker kit from farndon,power fc,1000cc injectors,GT3076,ported and polished cyl head,mahle pistons,8.5:1 comp ratio,cometic 5 layer head gasket(1.7mm),ARP head stud kit,ARP big end bolts,ALC bearings,bosche 044 and walbro fuel pumps siamesed together,SARD fuel press reg,Kent fast road cams and piper cam pulleys.jocster76 said:OAP 500bhp and 500lb/ft of torque sound like exactly what im after.
could you plz tell me the spec your running ? and who is mapping your car ?
duration isn't the issue with machining the head.oap-r said:Higher lift and longer duration cams will also require some head machining to make them fit.
You don't really need to go above 2 litres,it was just the path i decided to take.jocster76 said:im looking for good torque from idle like you oap but do you think i could achieve 500lb/ft from 86 mm pistons? i looked into stroker kits but the price wasnt on my side and im only got a bosche 044 pump which you have 2 and will 800cc injectors be up to the job
are you using uprated rods?
sorry for bein such a pest.
before i forget what box are planning on
JOC
I know duration doesn't dictate when machining is required smart **** ;-) but when people buy uprated cams it's usually with more lift and duration.diesel weasel said:duration isn't the issue with machining the head.
you can only go so far on standard or uprated gtir springs with the cam lift before the spring will bind, its safe up to 11.6 When you go much more over that you need to look at using de springs which have an installed height of 40mm as oppossed to 38mm for a gtir, this i why you need to machine spring seat to allow the extra lift.
all of which is more hassle than its worth in this instance.
for an easy option on a 2ltr chuck some 272's or similar in there and be done with it. Simon is running 264's but these limit his revs to 7000-7500, after that its all over, the 3076 would keep producing power higher up the revs but the cams make it pointless to rev higher
single 044 would be good for 650bhpoap-r said:iirc,the bosche 044 is good for about 450bhp.d.
