what boost?
what boost should i be running standard as the needle goes to the seven is this ok also what exhaust sound the best on the gtir
kyepan
have a go with the search facility and have a look in the tuning faq section.. it will answer your exaust questions.
I Generally find the best sounding exausts have holes at both ends and not much in between ;)
If your gauge is going to the 7 you could be running around 1bar , so it isn't standard. Standard is around 550mmhg I think.
If you like loud, the mongoose is good.
Rishi
Still waiting on some shims!
Could be the gauge... My mate just bought a UK spec GTiR... His gauge reads 14psi all the time but when we took it out with a calibrated gauge it was reading 0.65bar...
Some standard guages read better than others...
Rishi
The standard gauge is crap :wink: When i was running standard boost (10psi) my gauge was reading 12-13psi and my Blitz boost gauge was showing exactly 0.7 bar (10.15psi) 8)
i will have to get a nnother gauge then any ideas which is the best one and what should i mount it in
Rishi
Get any one you want...
I went for the HKS EL gauge - to match the iDials - with a GReedy pod for the A-Pillar...
Defi do some nice gauges...
Just have a look about and see what you want...
Rishi
R
ROSSGTIR
i thought 7 on the gauge is 7psi, thought 14psi was 1 bar :?
If you have a Pulsar the gauge reads in mmHg (millimetres of mercury) and 700mmHg is about 13.5psi. (14.5psi being 1bar)
I don't know what the uk (Sunny) gauge reads in, but if it's psi then yes, 7 would be 7psi :wink:
