Hi peeps,
An R I'm looking at has the following specs:
HKS forged 86mm pistons
HKS vernier pulleys
HKS 2.0mm head gasket
HKS valve springs
Kent cams (284)
The head has had extensive porting and polishing
The crank has been balanced and lightened
The con rods have been shot peined
Turbo is a MD214 roller bearing unit good for 400bhp+
Fidanza 4.5kg ally flywheel
AP paddle clutch (on / off)
Clutch support bracket
Dakar gearbox and diffs have been fully shot peined and rebuilt (professionally done)
Forge front mount intercooler with samco hosing
Exhaust manifold has been ported
Bailey dump valve
Mongoose full exhaust system from the manifold back to a 5” tail
Iridium plugs
K&N filter
Walbro fuel pump
Blitz sbc spec R boost controller
Apexi SAF-C2 computer
HKS 2.0bar boost gauge
Air con totally removed
Nismo shocks springs
Polly flex bushes on front end
Hi-Spec 285 big disc conversion kit
However is is only running at a max of 1.35 bar but I would of thought you could happily run at least 1.6bar :?
Opinions please 8)
for fuck sake another tuning oriented post!!!!
HKS vernier pulleys
HKS valve springs
Kent cams (284)
Bailey dump valve
Iridium plugs
K&N filter
Walbro fuel pump
Opinions please 8)
