What boost controller for high boost?
Can anyone suggest any boost controllers for running high boost levels, ie 35psi plus if desired.
How well do the likes of the apexi avcr etc work with high boost levels.
Need something that will hit and hold different boosts at the touch of a button (sort of thing) and will create fluctuatin boost.
Thanx, Ben.
stokie1
would suggest the best stand alone
management you can afford
GINGA
The stand alone ecu's boost controllers are rarely used as people tend to prefer the dedicated boost controllers.
Ben I presume this would be for your brothers car judging by the boost pressure so he might be best off with a air injector setup :?:
Yeah that right Paul.
His engine builder/mapper really doesn't like air injectors (he says they're unreliable and they're timely to set up right as you don't set a boost level, you set a duty).
Also means that if you change anythin the air injectors will need re mappin.
Dan wants somethin where you set a boost level and thats wot you get. And something that you can allter boost levels with a fair degree of ease.
Paul, wot have you found in your previous findings?
He's usin a bleed jet system at the mo, fail safe in that there's nothin to go wrong.
But he is really strugglin to get consistant boost levels and adjustment is a nightmare.
