What BHP expected ?
cmng
I have the following spec
Stock Cam
Forged Piston 87mm
Metal Gasket with lower compression
HKS GT2540 AR64 Boost 1.5 bar
Blitz FMIC 600mm x 300mm x 67mm
550cc injector
Stock MAF
Retuned ECU
Z32 fuel pump
plan to take it for Dyno next week
what figure i should expected ?
Thank
Rishi
Still waiting on some shims!
In theory 430bhp but with out a decent set of cams i will estimate 400bhp ish...
Rishi
D
danmo
I'd say about 380 - 400 cos the standard maf will be ristricting it, unless u have an emanage and it's bypassing the maf and using the map sensor, then could be 400+
Rishi
Didn't notice the stock MAF... Just glanced at the spec and saw Z32... lol
You won't be able to map to 1.5bar with that turbo on a stock MAF.... If you have done then you will be running very rich through the high torque / part throttle area...
Rishi
cmng
Yea.. the issue is stock MAF
i thinking to dyno first before i change the management
but 400 bhp on engine ?
i expected 300 to 330 only
Thank.. next week is dyno session
will update it with chart as well AF ratio
and upload my car pic as well since never upload it before
