Trip
Anyone would be able to determine an estimate weight of my car after i've removed all possible parts or replaced with lighter ones.
Here is the setup
Standard car (not RB)
Removed all interior including sound insulation. seatbelts, interior lights, stereo, speakers, door cards.
Only thing left inside car is dashboard, gauge cluster, pedals, steering wheel, one lightweight seat, a chromoly rollcage(32Kg), 2Kg Fire extinguisher.
Removed all the wiring harness apart from the ecu harness. made my own harness to operate fuel pump, radiator alternator metc. (just the essentials)
Fibre doors, with just the door lock mechanism. No side mirrors either
Fibre tailgate with standard spoiler.
Fibre bonnet with bonnet pins, removed the whole locking mechanism.
Plexi glass all round apart from the windscreen
Extra gearbox bracing
Bigger turbo (GT3071R WG)
Swirl pot 1ltr + extra pump
Removed All Aircon stuff including compressor bracket, cabin heater matrix, the lot
Removed wiper motors and all related mechanism
Removed the front and rear under bumper bars.
Removed ABS actuator
Removed the Y bracket and the other useless bracket
7Kg Battery
ARC TMIC
Added Oil cooler
Will also remove the standard oil cooler
Wheels+tyres x 4 = 64kg
Removed Inner wheel arches
Front Wilwood calipers + 2 piece 310mm brakes
Rear standard calipers 2 piece 310mm brakes
Tein coilovers
front lower + upper brace + 1 rear
Removed front headlights and will replace with one side inlet duct and the other just a fibre skin.
Added extra things such as MSD coil+amp, PLX Datalogger, and a shiftlight (max 3kg in total)
Larger Radiator
removed
AP elbow, down pipe, decat and straight single muffler exhaust.
I "wish" to get a 350bhp/tonne car :?
Anything else i could save on weight without using the grinder on body panels.:doh:
Here is the setup
7Kg Battery
ARC TMIC
Added Oil cooler
Tein coilovers
Larger Radiator
removed
