as some of you may know ive fitted a pulsar engine into my almera, now the car runs but like a bag of crap on idle, the emissions are way out, hydrocarbons are at 0.6
when you hold the revs at about 2000rpm the engine runs sweet as a nut, has any one had any simerliar issues with the pulsar engine
a few things to note,
there is no cat on the car
the engine has a almera temp sensor this is so the guage works correctly, but does it pass a signal via the ecu?
a few possible causes that we can think of up to now are as follows
the shims need setting up correctly as they where done when the engine was cold by the engine builder, so hence either not staying open for long or staying open to long
is it possible that the throatle bodys arent set up correctly
and only other thought is that the airflow meter is ****ed
having never worked on one of these engines befor any help would be greatfull
cheers
cheers
