Water temperature needle pointing to hot.....
R
riddygtir
The water temperature needle is pointing to hot and most of the time past it but the car is not over heating, hot air is blowing out and the car is holding water, what could it be? I have been told that it is probably a faulty water temperature switch. Please help. Thanks
very likely the sender unit is faulty!
remove the wire from sender unit and touch it to earth with the ignition switched on. if gauge goes right round to max then the gauge is fine and its more than likely the sender unit thats playing up
