gaz_127
how do you get waste gate chatter when i get my next R i want the noise of that instead of the usual dumpvalve sound nice imo
:roll: It isnt the wastegate chattering anywayBen said:Actually you get the internal waste gate to chatter by fitting a much larger actuator. You shouldn't remove the dump valve really because it will hurt performance
MarkTurbo said:And it dosent make one bit of difference to the performance either, especially as the engine hasn't run for months anyway :mrgreen:
:roll: :roll: :roll: I was waiting for you to say something :lol:kieron said:MarkTurbo said:And it dosent make one bit of difference to the performance either, especially as the engine hasn't run for months anyway :mrgreen:
:lol:
yeah your rightNad said:The word your all looking for is reciprocation. The effect can be amplified by having no dump/bov valve but can be heard if u have a metal air filter like the Blitz one. It is air backing up down the induction run and being forced over the blades of the inlet side of the turbo. This causes stalling which can increase lag and also cause damage in the long wrong. What is does do is save the car from overfuelling though if an atmospheric BOV is used.
Feel free to add other dis/advantages....
Nad
wrongcampbellju said:To BOV or not to BOV, that is the question......
that comes up frequently on many car forums for many years.
The general concensus has always been
BOV's increase lag :shock: but help protect your turbo.
Meaning the space after the turbo is at +ve boost. 8)before the turbo is at ATMOSPHERIC pressure, after the turbo its ABOVE ATMOSPHERIC
well if you honestly believe that then by all means go ahead an take it offcampbellju said:RIGHT :lol:
What you say is correct in that it will reduce turbo lag, effort to spin up again ... but it increases engine lag for the reason I previously stated.
Even in your answer you state
I don't think anyone will argue that having an oversized intercooler and extended pipe run from the turbo to throttle will increase overall lag all other things being equal. So why should having Atmos pressure in this same space cause less engine lag than positive pressure???
You've already answered that question and its going to be a compromise between the time it takes for the turbo to spin up to full speed again compared to the time it takes to fill the space acting as a reservoir before the engine.
So if you had a massive intercooler and pipe run, a DV must increase lag, if you had no intercooler and a tiny pipe run, a DV must reduce lag.
In theory what you say is correct but in reality, the turbo doesn't stall and forget what its doing, the space in the middle acts as an air reservoir and off the engine jolly well goes the next time the throttle is opened. Less overall lag even though "turbo" lag will increase.
To re-iterate before anyone starts taking the DV off, I would not advise it for non-360deg turbos because of the reliability concern.
i would like to make a comment. the reversed airflow will not make the turbo spin backwards. if you think about it there is hardly any weight of this air that has no where to go. the blades are spinning in excess of 150,000 - 250,000 rpms. also, there is always more pressure coming from the exhaust side. definitely more so that what would be in the pipes having no where to go. bov's were not even around when some of the best turbo cars were around in le mans and other endurance car races. if you can find any of the older videos anywhere form the early 80's thru to early 90's of these races you will hear some beautiful wastegate flutter. doesnt sound like a turkey gobble. these are the same low-tech turbos alot of us use today and what usually comes factory. they would use these turbos at max boost in excess of 40psi. no bov. i will try to find a couple articles of professional engine builders explaining the nonsense of bov's. there are documented tests showing that in comparison of using and not using a bov there is no difference in propellor speed during shifts. i have driven a few cars without bovs and i love that sounds. i've seen turbos with thousands of miles on them from cars with no bov's and they have no shaft or side play. the only thing i know for sure is that the use of a bov can be bad sometimes. if it leaks you could spike in psi and possibly cause detonation. the only bov i would ever use (and actually do use) is the hks ssqv. so i'm not saying they're stupid, just pointing out that there is no REAL reason to use one other than that psssssst noise. if it eases your conscience then go for it
I must be one of those tossers then :roll: Like i said before i've done 15,000 miles in my R with no dump valve and it hasnt affected my turbodevylboi said:well if you honestly believe that then by all means go ahead an take it off
no wonder there are so many broken R's cause there are tossers out there doing s**t they dont understand to their cars, im going to start a poll
