bensmith907
Wanted, Mines ECU.
must have a limiter.
Many thanks,
Ben
07795055304
Many thanks,
Ben
07795055304
Weren't they set at 85000rpm instead of 8500rpm or something stupid like that :lol:wrong the rpm limit should be 7800 i believe
there were 200 around units bought into uk which had a manufacture fault and had no rev limit at all, these have been responsible for destroying a few engines lol
Now that sounds very tempting! - The idea being that they'd buy a Nistune or similar board with a basic "Fusion Stage 1" map on it, that could be overwritten with something a little better at a later date? Or would it be a burn-and-forget job (PROM as opposed to EPROM chip on it)?You could get a basic daughter board for that. I could probably make and supply "mines" conversions for about £100 fitted.
you too huh!Why are you jealous?
That thought is going in the wank bank yumwhat jealous of george playing sheep and welshman on a cliff......................na...lol
Wouldn't be nistune the boards are relatively very expensive compared to a basic rom board, but re-tunable yes.Now that sounds very tempting! - The idea being that they'd buy a Nistune or similar board with a basic "Fusion Stage 1" map on it, that could be overwritten with something a little better at a later date? Or would it be a burn-and-forget job (PROM as opposed to EPROM chip on it)?
The max possible RPM assuming the CPU can keep up with it is 12750 rpm.Weren't they set at 85000rpm instead of 8500rpm or something stupid like that :lol:
I've seen between 7700rpm & 7800rpm on my ecu with the standard rev limit! Thats recorded both on my apexi and on my laptop hooked upto my wideband that takes its rpm signal from the ecu!
