Wanted: Blue Samco, 90deg
Smo
I'm after a short 90 degree Samco pipe with an inner diameter of (I believe) 80mm to replace the pipe off my Z32 MAF pictured below;
It can clearly be seen on the right hand side of the picture.
It must be blue please.
Smo
Depending how long it is mate I might be able to cut it, a picture would be ideal!
Smo
It's my fault for using Samco as a general term for hose. The make is unimportant pal - just after a 90 degree 80mm inner diameter pipe. As per your question, yes - I'm after 80mm each side.
Cheers.
gtir_pimp
you can get a new one on ebay for about £30. i did for my intercooler pipe to plenum. its a bit thinner than a samco one but it does the job and looks pretty!!!
Fusion Ed
Sorry I missed this post these are the elbow reducers I can supply:
19-13 mm
19-16 mm
25-19 mm
32-19 mm
32-25 mm
35-32 mm
38-32 mm
51-45 mm
60-51 mm
63-51 mm
65-60 mm
70-51 mm
70-60 mm
70-63 mm
76-51 mm
76-60 mm
76-63 mm
76-70 mm
89-76 mm
102-76 mm
I don't know if this will help you, I can give you a price if one of them is suitable, quality is as I said better than samco/sfs etc.
