bensmith907
I got my heart set on some mintex 1144's however when I come to order them No one has the rear pads:doh:. does anyone on here have a set? I need them QUICK!
Cheers,
Ben
Cheers,
Ben
What calipers have you got on the front? Generally using a more aggressive pad compound at the rear than the front brakes isn't a good idea ;-)what do you think about having 1144's at the front and 1155's at the back?
Demon tweeks is a negative. they only have EBC's and Black DiamondStick to 1144's all round.
This will give you a better balanced braking, also invest in braided lines all round this will give you a better "feel" when braking.
The rear brakes do quite a bit of work due to the transfer of power to the rear wheels due to the 4WD system, unlike a FWD car.
Try Demon Tweeks, they should have some rear pads in stock.
If you are doing track work then I would recommend 55's for the front or even DS2500's
Who is a mintex dealer in your local area? They should have no issue in sourcing the 1144's for you as I got a new set all round from my local mintex dealer. If you dont have a authorised dealer locally why not just directly contact mintex and they well be able to sort you out with a set or direct you to a dealer who definately has a set in stock (or should do).nope, no one has any, I think they are made to order. standard calipers BTW. (I know they need upgrading just not now)
Just a note too, I'm not sure if Mintex will have rear pads on the shelf (as there not big sellers), I know I've had to wait a week or two for my pads when ordering from Mintex?Who is a mintex dealer in your local area? They should have no issue in sourcing the 1144's for you as I got a new set all round from my local mintex dealer. If you dont have a authorised dealer locally why not just directly contact mintex and they well be able to sort you out with a set or direct you to a dealer who definately has a set in stock (or should do).
Yeah, I should of mentioned that I guess but Mintex still should be to give you an indication of which of their dealers would possibly be carrying stock if they arent able to get them out in a suitable time frame as buisness is buisness.Just a note too, I'm not sure if Mintex will have rear pads on the shelf (as there not big sellers), I know I've had to wait a week or two for my pads when ordering from Mintex?
Brave man or screw loose, that is the question!Going to the ring on standard calipers ..............offt
