Venting standard BOV to atmo
JamesB
To any ppl that have done this - a few questions
a. Does it screw with the idle and fuel consumption at idle
b. Does it improve/detract from performance
c. Does it sound ok
All in all, is it worth doing or am I just gonna end up plumbing it back in?
Thanx
GINGA
Don't bother it will cause running problems and stalling etc you may be able to get around this with a fuel controller to compensate for the unmetered air being drawn in but it won't be as good as getting yourself a bov designed for maf metered systems :wink:
Mulisha
If you plug up the hole where you took off the line to the intake why would it mess up. I think everyone means if you just remove it things will mess up.
ashills
no they arent ments for venting to air and will cause all sorts of running problems and its metered air ur dumping to atmosphere
GINGA
and when the throttles closed the vacuum opens the bov so the engine sucks in ummetered air through the bov and even worse unfiltered air :shock:
