vacl pipes HEEELLPPP
creedy
i need to know were the vac pipes from the fuel reg go and the black box on the back of the inlet manifold? do they connect together????
also does the wastegate connect to the inlet plem?
i 4got :oops:
petegtir
that looks like it will help. but tbh they all just need to be hooked up to the inlet. so they see the pressure/vac from the plenum.
creedy
ahhh rite thats ok then, so aslong as there all connected to the inlet they should be ok.
that pic looks alittle hard to work out in sum areas :oops:
